i5 750/760 will hit around 4Ghz easily enough. My 760 needs 1.2875v for 4Ghz or 1.35v for 4.2Ghz.
Had to play around with board voltages as well.
IMC 1.12500v
CPU PLL 1.8625v
PCH 1.0875v
Everything else is set to minimum (not auto) voltage. I would try to trim that 1.4v down a tad too. It would probably be able to be lowered quite a bit by running at 4Ghz. It's not as if you will notice the extra 200mhz anyway.
