Before anyone says "Sandy Bridge" let me explain.
I believe my current motherboard (in sig) is dying and its giving me a lot of grief. I have 16 days until I need to hand in a fairly large chunk of uni work and I need a system thats not going to give me any problems. I could get a new 775 motherboard from OcUK (the ASUS) for just over £82 but my thought process is telling me to go for the i5 system that will last me at least until after I get out of uni (around 8 months) and give me a small boost too.
The following from OcUK would cost me £309.97.
i5 760 2.8Ghz
Asus P7P55D-E
Corsair XMS3 4gb 1600Mhz
My Q6600 works great at 3.6Ghz and my current RAM is working fine too. I am thinking of getting the i5 system installed and having peace of mind without motherboard issues, selling my Q6600 and RAM on MM and burning the TPower i45 under a hot flame.
Yes I know if I could wait for SB it would be great, but truthfully I cannot. I cannot afford i7 either. I know that the i5 will give (when at 4Ghz) better performance then my current system, although for some it might not be worth the upgrade as my Q6600 is running 3.6Ghz stable.
Thoughts on the system spec above? Will it all work fine?
Thanks
i5 760 2.8Ghz
Asus P7P55D-E
Thanks
