Hi all,
My faithful X2 4200+ rig finally died so I picked up some new components;
* i5 750 2.66Ghz (stock cooler)
* Asus P7P55D (standard) mobo
* Corsair 4GB (2x2GB) DDR3 1600MHz/PC3-12800 Dominator i5 Memory Kit
CL8(8-8-8-24) 1.65V (CMD4GX3M2A1600C8)
The rest of the components remain the same;
* Thermaltake 480w PSU
* Thermaltake Tsunami Dream Case (2 large chassis fans and 1 side fan)
* XFX 8800 GTS 320Mb video card
* Samsung Spinpoint 1TB HDD
I've had problems with it occasionally locking up pretty much since I built it. I had the RAM timings set via the XMP profile (1600Mhz) but I figured that since the RAM is not on the ASUS confirmed compatibly list I'd set the BIOS back to Auto where the system sets it to 1333Mhz which I can live with if I have to. I also updated the BIOS firmware to the latest version.
This seems to have stopped it freezing but now I'm finding that it's completely cutting out / restarting when I put it though any kind of performance test (e.g. the COH performance test or HL2 Lost Coast video stress test). I've run prime95 for a shortwhile and it was OK, but the COH performance test will kill the machine everytime (pretty much at the same point in the performance test).
CPU temps are 40-45 idle with the stock cooler - which doesn’t seem unusual from what I've read elsewhere. So perhaps it's the PSU is not up to the job anymore?
I was planning on getting a better cooler and over clocking it at some point.. but at the mo I just want the thing to work reliably!
Any suggestions on what I should try next please?
Thanks in advance,
Rob.
Thanks in advance,
Rob.
I have one of these and find it to be an excellent psu and with being modular a lot less hassle with the cable management.
