i currently running the i59400f with my rtx 2070 i have been told that my cpu is bottlenecking my gpu can anyone suggest a good upgrade that will pair well with my 2070
This.You've been told?
Are you experiencing it for yourself?
Have you monitored CPU/GPU usage whilst gaming using something like Afterburner?
Waste of money, nothing worth upgrading to for the cost on that platform. Now if you went ryzen on the other hand....![]()
The 9400f doesn't out perform the ryzen 5 3600 nor does the 3500.If he went ryzen what? My 9400f out performs ryzen.. same as the 3500 out performs the 3600
Dont forget Intel core speed still trumps AMD. Most games still only used 6 or less cores and the one that use more like real cores not hyper threads
https://m.youtube.com/watch?v=EwONJYtX-5Y
It's easy to cherry pick
https://forums.overclockers.co.uk/threads/amd-ryzen-5-3500x-3900-non-x.18872604/
just some text that the guys probably made up.
All beachmarks can be manipulated. An overlay means nothing
You're a bit behind the times there. Older games or not well threaded, yes this can be true, but not anymore. Though it's not so much max FPS that is the problem. I do agree though, I wouldn't be switching to Ryzen from a 9400F and certainly not to a 3600.If he went ryzen what? My 9400f out performs ryzen.. same as the 3500 out performs the 3600
The Intel Core i5 was a little faster in a few of the games tested, but the R5 3600 was miles faster where you’ll notice it. So this one's pretty cut and dry unless Intel decides to cut pricing heavily.
The 9600K doesn't even out perform a 3600 so a 9400F has no chance...
