i7-11390H Any good for a CAD a workstation?
Depends what kind of work they're doing, if it is fairly light then sure, I guess so, but seeing as an i3-12100 is faster according to PassMark, it's unlikely to cut it for professional level work that hammers the CPU.
Depends on the CAD Software, but you "should" also have a discrete GPU. CAD software generally doesnt perform well with iGPU. even a cheapo 2nd hand Quadro can make a big difference.
It might be an 'i7' but it's a laptop processor.
Any reason why they need a mini PC as opposed to a regular atx pc?
Seems pretty big compromise to make unless you really need something small.
The story with most of these kind of processors (and there are much better 10 and 11 series H processors in mini PCs never mind 12 series) - if you are only loading up 1-2 cores and/or only putting them under heavy use in bursts they are decent, load up most/all the cores under sustained workloads and performance drops off a cliff compared to a similar on paper desktop chip.
