I7 13700 cooling furstrations
26 Nov 2022
London
Hello everyone my first post here,
I was wondering if I can get some advice on what to do please.
I purchased an i7 13700 with the intention of putting it a build that resides in a corsair 110R case and I realised that it has some pretty beefy cooling requirements that might be tricky with my case.
I was looking at aio coolers and I have now realised that my case isn't really compatible with them, or at least to my knowledge.
I'm a bit reluctant to change the case if absolutely necessary, is there any cooling solution that can work in my case. Or do I have no other choice but to change my case?
Thank you!
Hello, thank you for the advice, are you able to recommend a cooler that would be compatible for this size case and CPU?
Those are probably the most popular AIO out there for the average user.
It's plenty for a 13700k gaming rig, it's on sale atm and comes with the LGA 1700 upgrade kit included.
