- 20 Feb 2025
- Scotland
CPU: I7 14700K
COOLER: Lian Li Galahad II Trinity 360MM AIO (non performance)
MOTHERBOARD: Asus ROG STRIX Z790H Gaming
MEMORY: Corsair Dominator Platinum RGB 32mb DDR5-6000
GPU: MSI GeForce RTX 4080 SUPER
CASE: Lian Li 011 Vision
PSU: Corsair 100 Watt
FANS: 3 x 120mm LCD (Set to intake, mounted on AIO), 3 x 140mm (set for intake), 1 x 120 (set for exhaust)
Needing some help please as i'm totally stuck....never really messed around in BIOS or ever overclocked any chips.
My dad whos built many systems performed recent upgrade to my computer system. After getting system home, idling away fine at 35-42oc. As i went to install graphics drivers fans spooled up like a jet engine and temps where spiking at like 95-100oc!. Happened again whilst i installed Fortnite and a few other drivers. So After a lot of time investigating (googling/reading forums/youtube) this is currently the steps ive taken so far to try and mitigate the issue.....
Cooling... maybe adding an extra 120MM at the rear of case for better thermal regulation. Also going to swap AIO out tomorrow for my dads one to see if its a potential pump issue. Should i have got the "performance" variant?. I've tried running just fornite with a few diffrent bios settings ive seen online but the fans/temps are still spiking like crazy and its continuing to thermal throttle. Could it be a dodgey cpu? (can you test the cpu??). Getting frustrated now all i wanna do is play FPS with my fellow gamers online.
Thanks!.
- Updated to latest asus bios version
- Took off AIO.. re-pasted with Artex MX-6
- Made sure ive followed intels baseline settings (125pl short, 200pl long)
- Set an offset devolt (0.05000)
Thanks!.
