How far have you overclocked your C0 to? I had one and it wouldn't OC well, wouldnt get to 3.6 without silly settings. So I swapped for the D0, now it just sits there at 4ghz and thats enough for me.
.Yes they run cooler.
Something tells me contradicting Greebo is going to be a bad call. However, I believe you to be wrong on this note sir. Couple of references, best link I could find for some reason http://www.xtremesystems.org/forums/showthread.php?p=3779420
The D0 runs at lower voltage but draws more current. Reported figures are around 20W more at the wall, so it's drawing more current. This likely does bad things for electron migration, and clearly doesn't help temperatures, but otherwise matters little.
edit: Just in case, Power = Voltage x Current. Damned crude equation, but gets the point across and remains pretty valid when using rms values for varying quantities. Reduce voltage, but raise current, and you can end up with more power used and so more heat generated.
Something tells me contradicting Greebo is going to be a bad call. .
My c0/c1 is a pretty good chip itself. 3.875 stable at 1.19 volts. I have yet to see any other i7s at the clock with volts that low. And yes before you ask it is prime stable and if you want the screenies to prove it they are already on here if you do a search.
My point to that was, a good c0 chip is better than a bad d0 chip. I read a thread on here where someone couldn't get his d0 to overclock very well. Granted the vast majority probably have no problems at all.
Wow, that is a very nice C0 chip. Better than my D0. 4GHz @ 1.2v
That's what I said to someone else asking if it was worth changing. You could end up swapping to a D0 chip worse than a C0 chip. Due to the CPU's capabilities being random, there's no guarantee D0 is better than C0. Averages might suggest it is, but there's bound to be ones that aren't. For every above average result, there's some below average too.
