I'm trying to get above 4.6 GHz but I'm not having much luck. I live in a warm, south-east facing flat, so ambient temps are quite high. I have a good case and good CPU cooler so not much I can do there, though maybe I guess I could reseat the H70 to see if I messed it up when fitted.
OK so I have it currently at manual 1.37VCore, and this allows a stable 4.6GHz overclock, mid 30's idle and high 70's load.
I'd like to use CPU offset, so when my PC is sat doing nothing, VCore drops, but I can't seem to manage it.
I have Load-Line Calibration set to extreme, and if I set the offset to +0.02 VCore reaches way over 1.4V under load. If I set it under 0 then I get instability. I have tried putting Load-Line Calibration to high instead of extreme, but then I get instability.
The only way I get stability atm is to use manual VCore which is what I'm trying to avoid.
Memory is set to XPM and V on the sticks is at 1.6V
Help please?
Help please?
