Hi,
I would be grateful if anyone can give me some advice on things to look at to try to resolve a BSOD with an i7 2600k that occurs minutes after starting Prime95.
I am using an ASUS P8Z68 Deluxe motherboard and I used the AI Suite Turbo tool to achieve the overclock rather than a manual overclock. I did it this way as I am a total noobos at overclocking and this seemed a safe place to start !!
The AI Suite settled on an overclock of 4.43GHz and the PC booted up OK. However, minutes after starting Prime95 and RealTemp I get the BSOD. Temperatures before the BSOD are mid sixties and look to be OK.
The system is stable at the stock CPU speed and runs Prime95 and RealTemp OK without crashing with temperatures around the mid fifties. I am using a pair of Noctua NF-F12's on a Corsair H80 with the fans connected to the board CPU fan header with a PWM Y connector using the LNA adapter adapter to keep the fan speeds to a max of 1200rpm.
At the moment, I am not sure if it is the settings applied by the AI Suite to achieve the overclock that is causing the BSOD or if it is hardware related. I suppose the best option would be to discard the AI Suite overclock settings and manually overclock the CPU bit by bit. However, for a mega total noobos to "clocking" that seems scary?
Any advice most appreciated.
Thx
Bintos
Thx
Bintos
