I7 2600k CPU FAN
Depends on the case... if you've got clear access to the rear of the board to fit the backplate then you can probably fit it with the mobo in the case... if you can't quite get to some of the holes (like my board in my HAF) then it'll probably have to come out...
It's not a rule that it HAS to come out - it's all down to whether you can physically do it with it still in :)
