Hello.
Im reletively new to Overclocking. On my old E8400 Core 2 Duo (3Ghz) i overclocked it to 3.8Ghz buy upping the FSB, i kept it on stock voltage because i was a bit worried that increased volts would damage the CPU its self.
Now that ive Upgraded to an i7 2600k, Gigabyte P67A-UD4-B3, and 8Gb Corsair Vengeance 1600Mhz Ram i thought id give the i7 a good overclock while staying on stock voltage.
Here is my First Attempt:
Set all CPU voltages in the Bios to "Normal" instead of "Auto" and disabled LLC.
i then upped the multiplyer from 34 to 40.
Is this Ok to do? What exactly is LLC? and how does it affect my system?
Will keeping the voltage on all the other CPU related volts on normal have any adverse affects?
Thanks.
Thanks.
