Permabanned
- 17 Feb 2009
Can I just go into my motherboard BIOS (Gigabyte) and just change the multiplier to 40... so i clock at 4ghz, and leave everything else as default and not have any problems?
Or do I have to change Voltages etc
Id like to think I could do something simple like that
- Also if I did this and it was OK, do I have to use PRIME etc? Do they make the system stable or just 'test' it to see?
I mean couldnt I just take a risk and hope that my change worked and if it crashes, then just set to default next time round?
- Also if I did this and it was OK, do I have to use PRIME etc? Do they make the system stable or just 'test' it to see?I mean couldnt I just take a risk and hope that my change worked and if it crashes, then just set to default next time round?
