i7 2700k low Gflops
13 Nov 2011
Lost somewhere.......
Just noticed when running IBT my Gflops have gone from 126ish when i first overclocked my chip, down to 98 - 100 now, not changed any settings:confused: anyone know why this is ?
tested without multithreading enabled? try with it turned off its just ibt not the cpu,gflops should be a lot higher with multithreading disabled
Thats more like it
Cheers mate you put my mind at rest, thought i had degraded my chip benching @ 5+ GHz with a high vcore:eek:
must have had hyperthreading off when i first overclocked, i always have it enabeld thats what i bought it for, encoding etc:D
Thanks again
There are a number of resources that are shared between the threads like cache etc.. If the threads are competing for said resources then you'll end up with a performance loss. Hence with HT off you have less threads and less competition, equals a performance gain. This is why some unoptimised software can run worse with HT on, this is how i understand it anyhow.
a good test to see the advantage boost of multithreading is cinebench cpu test,youll see how much higher the score is with it enabled
Thanks for the info, i do like to understand why these things are, it makes sense when you put it like that.
