- 11 May 2006
I haven't overclocked a CPU in ages and would like some advice, but below is my first attempt at something stable and for 24/7 use:
This is on an Asus P8Z68-V/G3 and I pretty much just upped the turbo multiplier to 46 and left everything else on auto, except memory setting which I set to 1600mhz/9-9-9-24-1T/1.5v as stated on the specs.
Mostly worried about voltage and what exactly is safe for 24/7 usage (or at least normal usage). I've seen the voltage spike to 1.4 when the frequency goes up to 4.6, but it's only momentary.
Is this safe or should manually tweak the voltages, if so, what would you recommend?
I'm happy with 4.6ghz for my purposes, but don't want to damage the CPU or anything.
