Hi their,
I have a i7-2700k @ 4.6Ghz and while it is and has been a great CPU, I really have the upgrade itch. I have put off changing my CPU/motherboard so many times as I keep reading that it's just not worth it for 90% of things, but this still doesn't stop me having the itch.
If I was to upgrade I'm looking at either a 6700k/5820k or 6800k. Also at the same time I would buy a M.2 drive with the new setup, but as well are these worth it compared the "conventional" SSD drives?
Now here comes the thing. I use my PC mainly for gaming and I know the gains won't really be noticeable in that department, I would like to try doing a bit of streaming someday. So I was wondering if I could have some opinions from you wise lot
Have any of you upgraded from the same or similar CPU, and how did you find it? Did you actually notice FPS gains? Or was your minimum FPS increased ect?
If choosing between those CPU's, which would you go for? I know the 6700k is the marginally better gaming chip, but I am worried if I go for the 6700k that in the future at some point the extra cores of the other CPU's might be useful. Will a 4 core CPU be plenty future proof in gaming? I plan to keep the new CPU/MB/RAM as long as I have my sandybridge setup.
I game on a 2560x1440 144Hz monitor. PC specs are in my sig. Thanks in advance all
