Well after much deliberation I have gone ahead and delided my CPU, I was originally going to run without the IHS but decided to try with first, I can say it has made a good deal of difference to the temps.
It has reduced the temps from between 11 to 15 degree reduction across the cores when running prime with a 4.5Ghz overclock this is under a custom water loop I may add, overall I'm happy with the reduction.
