i7 4770k info
31 Jul 2011
just wondering if you guys can tell me if this looks good, just upgraded to 16gb of ram from 8gb, im now using all 4 dimm slots, would have liked to go for 2x8gb sticks but couldn't be arsed with the hassle of selling the old 1's first ;)
my overclock remains the same as before and seems stable, im overclocked to 4.1ghz and thats as much as i can get out of my ****** chip on air using a dark rock pro 2 cooler, anyway my question is.... does the fsb:dram look correct and what about the NB frequency.
the ram i have is G-Skill 8GB Ripjaws X DDR3 2133 Dual Kit x2 and i have set the bios settings to the xmp profile with the ram voltage at 1.5 although it states in the uefi bios 1.43, thanks in advance guys
Looks ok to me.
Your NB frequency looks rather low though, it should be .2 off the clock speed so if your CPU is at 4.1GHz i'd set that to 3.9GHz if that makes sense.
Now the fun part is tweaking the timings to see if you can get them lower. Normally you should be able to change the memory from CR 2T to 1T
Here is a screen shot of mine
