i7 4770k integrated GPU
If I connect my monitor to my discrete GPU's DVI output, if I use the integrated 4600 GPU, will there be video output?
Yes, but the video output will be driven from the discrete GPU, not the iGPU in 4770K. The only way for you to "use" the iGPU is to connect your monitor to the video output(s) of your motherboard.
don't forget you may need to enable the onboard gpu in the bios, especially if you have a discrete gpu also installed.
