OK, yet another thread by me and my determination to get a 4.5Ghz overclock!
I have struggled to get anything past 4.2Ghz so there must be a setting(s) somewhere that I must need to change. And this time rather than seeing my overclock in the dark I have spent ages writing down each setting, and here we are:
So this is currently a 4.2Ghz overclock stable (5 runs with RealBench), running 4 sticks of DDR3 at its native 2400Mhz with XMP.
Surely someone can take a peek at these settings and determine what I need to change to achieve a 4.5Ghz overclock. Simply raising the vcore to 1.3v is not enough even at 4.3Ghz.
I would really appreciate some suggesting what I need to change
Cheers
As you can, tons of options[Extreme Tweaker]
AI Overclock Tuner - XMP
-- XMP DDR3-2401 10-12-12-31-2N 1.65v
CPU Strap - Auto
PLL Selection - Auto
Filter PLL - Auto
BCLK Frequency - 100.0
ASUS MultiCore Enhancement - Disabled
CPU Core Ratio - Sync All Cores
-- 1-Core Ratio Limit - 42
-- 2-Core Ratio Limit - 42
-- 3-Core Ratio Limit - 42
-- 4-Core Ratio Limit - 42
Min. CPU Cache Ratio - Auto
Max. CPU Cache Ratio - Auto
Internal PLL Overvoltage - Auto
BCLK Frequency : DRAM Frequency - Auto
DRAM Frequency - DDR3-2400Mhz
XTREME Tweaking - Disabled
CPU Level Up - Auto
CPU Core Voltage - Manual Mode
-- CPU Core Voltage Override - 1.220v
CPU Cache Voltage - Manual Mode
-- CPU Cache Voltage Override - 1.220v
CPU System Agent Voltage Offset Mode Sign : +
-- CPU System Agent Voltage Offset - Auto
CPU Analog I/O Voltage Offset Mode Sign : +
-- CPU Analog I/O Voltage Offset - Auto
CPU Digital I/O Voltage Offset Mode Sign : +
-- CPU Digital I/O Voltage Offset - Auto
SVID Support - Auto
Initial CPU Input Voltage - Auto
Eventual CPU Input Voltage - Auto
DRAM Voltage - 1.65000v
PCH Core Voltage - Auto
PCH VLX Voltage - Auto
VTTDDR Voltage - Auto
DRAM CTRL REF Voltage - Auto
DRAM DATA REF Voltage On CHA - Auto
DRAM DATA REF Voltage On CHB - Auto
CPU Spread Spectrum - Disabled
BCLK Recovery - Enabled
[External DIGI+ Power Control]
CPU Load-Line Calibration - Level 5
CPU VRM Switching Frequency - Auto
VRM Spread Spectrum - Disabled
Active Frequency Mode - Disabled
CPU Power Phase Control - Optimized
CPU Power Duty Control - T.Probe
CPU Current Capability - 120%
CPU Power Thermal Control - 120
CPU Input Boot Voltage - Auto
DRM Current Capability - 100%
DRAM Switching Frequency - Auto
DRAM Power Phase Control - Auto
[Tweakers' Paradise]
Initial BCLK Frequency - Auto
VCCIN Shadow Voltage - Auto
Termination Anti-Aliasing - Auto
Initial PLL Termination Voltage - Auto
PLL Termination Reset Voltage - Auto
Eventual PLL Termination Voltage - Auto
PCH ICC Voltage - Auto
Clock Crossing Boot Voltage - Auto
Clock Crossing Reset Voltage - Auto
Clock Crossing Voltage - Auto
[CPU Internal Power Saving Control]
Power Saving Level 1 Threshold - Auto
Power Saving Level 2 Threshold - Auto
Power Saving Level 3 Threshold - Auto
[CPU Power Management]
Enhanced Intel SpeedStep Technology - Enabled
Turbo Mode - Enabled
CPU C-States - Disabled
[Turbo Mode Parameters]
Long Duration Package Power Limit - Auto
Package Power Time Window - Auto
Short Duration Package Power Limit - Auto
CPU Integrated VR Current Limit - Auto
[CPU Internal Power Switching Frequency]
Frequency Tuning Mode - Auto
[CPU Internal Power Fault Control]
Thermal Feedback - Auto
CPU Integrated VR Fault Management - Auto
[CPU Internal Power Configuration]
CPU Integrated VR Efficiency Management - Auto
Power Decay Mode - Auto
Idle Power-in Response - Auto
Idle Power-out Response - Auto
Power Current Slope - Auto
Power Current Offset - Auto
Power Fast Rampe Response - Auto
[CPU Configuration]
Intel Adaptive Thermal Monitor - Enabled
Hyper-Threading - Enabled
Active Processor Cores - All
Limit CPUID Maximum - Disabled
Execute Disable Bit - Enabled
Intel Virtualization Technology - Disabled
Hardware Prefetcher (L2 Cache) - Enabled
Boot Performance Mode - Max Non-Turbo Performance
Dynamic Storage Acceleration - Disabled
Cheers
