Hi,
Ive tried to overclock my I7 4770k on an asus z87 pro a couple of times but the temps are extremely high and in the end i gave up. The cooler is 212 evo.
On default settings, in prime 95 it gets up to 80-90C. If i try to move the multiplier to 41/42 then it gets to 95/100C. The only way to keep it under 90 on 41x is to set the voltage at 1.15/1.14 but its not 24/7 stable.
Can someone help on what the issue could be?
Bad cooler? Bad processor? Not doing the bios settings correctly?
