I7 4790 vs i5 7600k confusion
17 May 2020
So I will post two pictures first one will be a mates i7 4790@ 3.8ghz and my 4.8ghz i5 7600k I'm a little confused as to how he achieved a higher score and not even by a little bit, to my understanding the 7600k is quicker as it's allot newer even at stock speed let alone boosted to 4.8. Any clarity would be appreciated.
BtPuuFR
myRAfSw
Pictures no worky.
Strange, ok his cpu score was 910 and mine was 688. Quite a noticeable difference
He has an i7 while you have an i5.
His i7 is a 4c8t part, while your i5 is a 4c4t part.
He has a stronger multi-threaded chip, in scenarios that don't make use of the extra threads your 7600K will be faster. That said, software and games in general are becoming more multi-threaded not less, so going forward his i7 will be superior in most scenarios.
Benchmark is also a bit meh, I downloaded and installed it to have a look. If it makes you feel better my Radeon 7 scores less than both of your r9's!! Heavily weighted to good old Direct X 11 performance at 720p as you do.
Well goddamn there goes my bragging rights, looks like I'm getting the 10900k in a few days lol
What, how's that even possible lol
wana see:
Benchmark is flawed. This is with default memory speeds not my overclocked "gaming" profile. DX11 720p is not what radeon 7 is all about. You want to be at like 3440 or 4k where the card has the performance. Compute counts for little in that benchmark. Also the cpu run is so light/small it doesn't even fully load up my chip before it drops off.
wana see:
Wow that's incredible, look at that cpu score though lol, is there a more reliable bench that you know of?
wana see:
It's definitely off in a couple of ways.
Here's what I got with the rig I'm on currently:
Everything at stock, that's a 1600AF.
I bet you if I unplug the rift it will shoot up. Unless almost everything dominates radeon 7 at 720p lol.
Personally I wouldn't worry about it. I used to care. Now I just play the games. Dont bother with the benches unless I think something is wrong. I might try this on my wifes 2700x rig with rx470. I bet it beats mine in GPU :)
Same.
I run the couple of benchmarks when I set something up just to make sure everything is running how it should be, then I just forget about it and get on with gaming or whatever it is I want to do.
