I'm running on air (CM V8 GTS) can't remember what paste I've used but it's 'high end' from my mate.
Basically, earlier running L4D on [1920 x 1080], [4x MSAA], [4x Anisotropic Filtering], [VSync (Double Buffered)], Shader Detail [V High], Effect and Model/Texture Detail [High], Multicore Rendering [Enabled], Paged Pool Memory Available [High].
Using HWMonitor my max CPU temp was 66 degrees C... Seems higher than it should be, especially considering my GPU's max was 40 degrees?
Need to know is this normal - my friend in his PC I built for him just yesterday has an i5-4690K had max CPU temp of 56 - granted his settings were lower but still, 10 degrees for a few settings changes? (was more or less, resolution, his was notably lower, and no MSAA I don't think).
Thanks
Thanks
