- 19 Nov 2011
Hi Mr 8 Pack,
Wondering if you can help me with my Overclocking setup, I have recently upgraded the X79 and really like the extra power + Heat! However, I currently have her sat @4.625ghz with the 125 CPU strap @1.410 vcore.
I'm under a full loop so temps never exceed 60 degrees.
I currently have 16GB (4 Modules) of Hyperx Beast RAM currently clocked @1333 mhz. This isn't deal, and thought I would ask to see how I can get the clocks up further, and fine tune my overclock a little better.
My system spec is:
ASUS Rampage extreme IV
i7 4930k
16GB 1600mhz Hyperx DDR3 RAM
For now my settings are as follows:
Vcore @1.410
CPU Vdroop: High
CPU Currently capability: 130%
VCCSA LLC: Regular
VCCSA capability: 120%
Both DRAM AB and CD current capability: 120%
Both DRAM AB and CD phase control: optimised.
CPU VCCSA volts: 1.100
VTTCPU: 1.100
CPU Spread Spectrum: Auto
Intel adaptive thermal monitor: Disable
Antisurge Support: Disabled
Any help on upping the RAM, and any extra voltage adjustments would be appreciated.
Many thanks!
My system spec is:
i7 4930k
Vcore @1.410
CPU Vdroop: High
VCCSA LLC: Regular
VTTCPU: 1.100
Many thanks!
