Hi all,
I've done a build with an i7 5930k CPU, MSI X99S Gaming 7 motherboard, MSI R290x GPU and a hyper 212 evo heat sink + fan (link below). Oh and an EVGA gold standard 850W PSU.
Heat sink + fan:
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
After booting up the motherboard (testing outside the case with just the GPU fan and heat sink fan running), in the BIOS, I watched the CPU temperature, which settles around 38°C, when navigating through the BIOS it can touch 39-40°C. Is this a good average temperature to settle at? If not, could this be because its out of the case with less fans running?
Shaneo
Heat sink + fan:
Shaneo
