i7 6700k at 90c at full load?
14 Sep 2014
My i7 6700k was at 90c when I ran Prime95. Is this normal? The cpu was not overclocked and I was using the Intel stock cooler from 3770k
Was it part of a ready made bundle or have you mounted it your self. It won't have damaged anything at 90° but even a cheap cooler should keep it well below that.
What your BIOS settings/system info. Particularly voltage readings from something like HWMonitor?
I would buy a decent cooler soon
i went for a noctua nh-d15 seemed like overkill size and price wise
but worth it for the performance and sound levels well below 50c load and nearly silent (No overclock yet)
