purchased the OEM version in early september 2016, I use a noctua fan cooler on it which has a single 120mm fan. Asus Z170 Sabertooth motherboard
My issue is with overclocking, ive tried multiple times to overclock it using the method that all the youtube channels say and I get the same results:
- My pc random freezes every couple of hours for 5-20 seconds
- My CPU fan is quiet as usual and then just shoots up to 70c every 5-10 minutes and the fan starts going crazy for a few seconds
- I dont see much if any performance change
- in games the cpu fan goes crazy aswell with temps of up to 80 with 100% fan speed
- CPU-Z doesn't display the overclock at all
I dont understand what im doing wrong? Are the fans meant to be going mental when you have overclocked it?
Im considering getting rid of it and the motherboard for a 8700k, is it worth it?
thanks
thanks
