Hi OCUK Community!
Long time no see
I've recently upgraded to Skylake system, here's the spec:
i7 6700K
Avexir White 2x8GB DDR4 2400MHz (@2133MHz)
MSI Z170A XPower Gaming Titanium (BIOS V1.2)
MSI GTX750Ti (at the moment, will upgrade next month)
Custom H2O loop for CPU (240mm rad, push-pull) [Distilled water as coolant]
Some HDDs
8 fans (5x Corsair, 3xAerocool Orange Shark)
Corsair 540 Air.
Now:
I managed to OC my CPU to 4.6GHz with 1.175V (mobo allows auto-increase of 0.05V so it sometimes go up to 1.225V).
Temps are as follows:
IntelBurnTest 70C~ (30 Passes of custom [12GB])
OCCT 55C (1h, 90%)
Gaming 30-40C
Idle 23C.
I am having a feeling that temps for Intel Burn Test are a little bit too high, especially for this voltage? Thermal Paste used is Arctic MX4 (using this since I build PCs [Q4 2013]).
I am aware of the fact, that IBT is EXTREME, and that there is no game that would push my CPU to that much stress..
My CPU managed to easily overclock to 4.8GHz (had 4.9GHz running Cinebench and scoring 1063 points), however 5GHz required 1.45V (I've set 1.35V but thanks to the BIOS, it automatically pulled 0.1V more).
I have set override mode, although if needed, it pulls up to 0.1V more than set, which is annoying me much.
What do you guys think: is 1.175V any good for 4.6GHz OC? From image you can see it uses more voltage than set in BIOS.
I am not looking to OC my memory, we all know it gains no performance in gamer's life.
Long time no see
i7 6700K
Some HDDs
Corsair 540 Air.
Now:
OCCT 55C (1h, 90%)
Gaming 30-40C
Idle 23C.
