- 11 May 2006
Hi all,
I just setup a new system around a 6700K and have attempted to overclock it. Right now I am up to 4.8ghz, with load voltages at 1.42v (with the odd spike to 1.44v) and temperature staying under 89C. My bios settings are:
Below is my last run of IBT:
http://i.imgur.com/LRntSGj.jpg
For reference the rest of system is as follows:
Everything seems stable now, but just wanted to check if the temps and voltages are safe for normal day to day use. I know 89C is pretty high, but this is only with IBT; it stays around 80C under normal loads.
I haven't overclocked anything since the Sandybridge days and just worried that I might be doing something wrong. Would appreciate any thoughts or advice.
Ai overclocker tuner: XMP
BCLK: 100
CPU core ratio: sync all cores
1-core ratio limit: 48
CPU core/cache current limit max: 255.50
Min CPU cache ratio: auto
Max CPU cache ratio: 44
CPU core/cache voltage: adaptive mode
Offset mode sign: +
Additional turbo mode CPU core voltage: 1.390
Offset voltage: auto
Dram voltage: 1.3550
CPU VCCIO voltage: 1.1500
CPU system agent voltage: 1.1500
PCH core voltage: 1.00000
FCLK frequency: 1ghz
BCLK: 100
Offset mode sign: +
Asus ROG Maximus VIII Hero Motherboard
Corsair Vengeance LPX 2x8GB DDR4 3200MHz C16
Corsair AX760 PSU
Corsair AX760 PSU
