Just a curiosity question. When I first setup my 6700k (under TRUE Spirit 140 rev.A) it ran significantly hotter than it does now in same system with same settings. Temps seemed to slowly but progressively get lower with each startup, heavy load, shutdown cycle. End result is it is now running about 7c, maybe a little more lower than when new. It's not CPU TIM set because I have used many different coolers. The TRUE Spirit 140 rev.A is uses to verify baseline, usually ran before and after a test session., and when I was getting these lower temp discrepancies I would re-seat and test to verify. I never had a temperature rise, now lower in all of the remounting and use. Is it me going crazy or have others had this happen? Especially experienced user like yourself.
