I7 6700k Z170-E
10 Feb 2011
I asked over clockers if they did a profile for this CPU and board but they said they dont give out there profiles but they did try and help. They said to do this which I have done and everything working.
Enter BIOS, Go Advance mode
A.I Tweaker
AI Overclock Tuner - XMP or Manual (Use XMP if available)
(If XMP not available) DRAM Frequency - 2400Mhz
CPU Core Ratio - Sync all Cores
1 - Core Ratio - 45
Digi + VRM
CPU Loadline Calibration - Level 7
CPU Core/Cache Voltage - Manual
Core Voltage Override - 1.32v
DRAM Voltage - 1.40v
CPU System Agent Voltage - 1.20v
Anything else to change or add to this?. Thanks.
When I change DRAM Voltage to 1.40 it changes to 1.4058 and goes purple.
When I change CPU system agent to 1.20 it changes to 1.20000 and yellow. Is this normal?.
I cant believe it. I Tested all day and now no mouse lag. Ive only tested No mans Sky but I was having problems in other games too and now I can aim normal with out the feeling of lag. Even windows mouse feels very different. All I can say is Thank you OCUK. I still might buy another PC as I did tell my brother kid if I did I would give him this one for his first PC. Not tested temps but everything in game seems fine and no stutters or any problems. :D
