i7-7700k and non oc stock temps
12 Feb 2017
are i7-7700k and non oc stock temps ok, or are they something that needs attention, what i mean is non overclocked but turbo'd up, on a good air cooler (dark rock pro 3) are those temps worryingly hot, or do those sort of temps only happen with oc'ing? does that make sense....
thankyou for any and all help.
The TJ max for Kaby Lake is 100 degrees. I'd say anything under 70 degrees under load is optimal. But as long as you're not going above 80 degrees its perfectly safe long term.
