i7-7700K How many cores ??
5 Sep 2017
Essex
Hi Guys
Last year I bought a i7-7700K CPU. I have been doing a little investigating as I was about to see if I need ant updates etc. I noticed that my CPU only has 2 Cores & 4 threads.
All the info I can find on the i7-7700K it is supposed to have 4 Cores & 8 threads???
I'm using an ASUS Z270E MB btw.
Any help gratefully appreciated.
Maybe you have them disabled in Windows.
Go to Start > Run > msconfig > Boot tab > Advanced options > Number of processors should NOT be ticked.
Also check your bios that all cores are enabled; it should definitely be 4 cores 8 threads.
I tried all of your suggestions and I'm happy to report the missing Cores/Threads have now turned up..:D
Thanks Gents
