Hi guys,
I've recently knocked together an ITX system with a 7700K in it and was just curious about the temperatures I'm seeing. I'm not concerned about them, but wanted to check that they're in-line with what it should be.
CPU is at 100% stock speeds at the moment and under Prime 95 (non AVX) load testing it was reaching around 73 degrees C. I delidded the chip and relidded it and now I'm topping out at around 60-61 degrees C so that's a pretty good result there.
I'm just curious about whether these temps are normal or not. Like I say, I'm in no way concerned about them, but since I haven't really been able to find too much info about temps at stock, I'm not sure if this is good, bad or just normal...
