- 30 Aug 2017
Hi all,
Been a lurker for years and finally got round to splurging on a big rig. I'll include the specs below but perhaps useful to put the question i have up here as i am not sure if i have the right section.
Essentially, i have an i7 7820x (please no 'but y not Ryzen' questions from the valuepolice) and I have a be quiet! 360 silent loop AIO cooler. I just wanted to ask other 7820x owners what kind of temperatures they are getting at stock and at idle because i am not sure if i have a terrible 7820x thanks to the silicon lottery or the bequiet! AIO is not good enough (or both?)
I have overclocked to an all core 4.2Ghz at 1.08v which seems to be stable. I replaced the stock fans on the bequiet AIO with 3x Noctua NF12s in a push configuration.
When running:
AIDA64 temps get to around 60-65 degrees.
Cinebench R15 temps get to around 80 degrees.
I managed to get a stable overclock of 4.7Ghz at 1.25v. At this overclock:
the AIDA64 CPU stress test gets to around 80 degrees
the cinebench r15 reaches 105 degrees (i was hesitant but let this one run till completion as the cinebench multithread run is not too long).
It seems as though there is a sweet spot of 4.5Ghz at around 1.15-1.2v however i prefer silence hence the 1.08v 4.2ghz clock.
I have read about some people reaching 4.7ghz at 1.2v with completely manageable temperatures (not the 100+ degrees i reached in cinebench). I have reapplied the TIM 3 times as i thought maybe i had not done something properly, but there is no statistically significant reduction in temps.
So back to my question: Is it a crap 7820x, a crap cooler or a combination of both.(or the skylake x series is just a beast?)
Bonus question: is it worth trying a different AIO? The reviews i read for the bequiet 360 silent loop were all very positive.
Would appreciate any help/advice anyone can offer. If you have any further questions please do let me know! I've included my build below:
Intel Core i7-7820X 3.6GHz (Skylake X / Basin Falls) Socket LGA2066 Processor - Retail
Asus Prime X299-Deluxe (Socket 2066) Intel X299 ATX Motherboard
G.Skill Trident Z RGB 32GB (4x8GB) DDR4 PC4-25600C14 3200MHz Quad Channel Kit (F4-3200C14Q-32GTZR)
EVGA GeForce GTX 1080Ti SC2 HYBRID 11264MB GDDR5X PCI-Express Graphics Card
Seasonic Prime Titanium 850W 80 Plus Titanium Modular Power Supply
Samsung 960 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
Asus External USB Blu-Ray Rewriter (SBW-06D2X-U)
Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Gun Metal
be quiet! Silent Loop Superior Liquid CPU Cooler - 360mm
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)
Razer Blackwidow Chroma V2 Mechanical Gaming Keyboard - Razer Green Switch
Razer Lancehead Tournament Edition Ambidextrous Optical RGB Gaming Mouse 16000 DPI
Noctua NF-P14s REDUX 1200RPM 140mm Quiet Case Fan
Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan
Arctic MX-4 Thermal Compound (4g)
When running:
