Right i've been tasked of building a rig up for £800 and i've come to a bit of a hurdle when choosing between an i7 860 or an i7 920.
Now the machine will be a purely music/audio editing machine using many VST's and plenty of audio rendering etc.
Now i've specced up 2 machines and the i7 920 rig comes in just about on budget at £800 (6GB RAM & X58 Mobo). However the i7 860 comes in nearly £75 cheaper at £725 (4GB RAM & P55 Mobo).
I've read the performance is negligble at best between both the 860 and the 920 and that there isnt much performance difference having 4GB of Dual Channel compared to 6gb of Triple Channel memory. Some benchies have also said the 860 is an allround better chip due to it running cooler and using less power.
Now a £75 saving is quite a lot (it's for a Charity organisation) and I'd just like some people's opinions off here as to what you think I should do, if I should stump up an extra £75 and go the 920 route with 6GB RAM, or save the £75 and have an 860 with 4GB RAM (especially if i'm not going to notice much (if any) performance increase spending the extra money.
Hope i've made sense, any help is massively appreciated.
Thanks.
Thanks.
will come round and OC if for you. (unless your 12 then your dad will have to be there)
