Hi, I recently bought an i7 8700k and am trying to overclock it to at least 4.7GHz. Unfortunately I can not get it stable at anything past 4.5GHz even at 1.4v. This is using fixed voltage. I am using OCCT to test stability and so far I have only got to 4.5GHz using 1.3v. Another thing I've noticed is that even when using the highest LLC level available, the voltage under load still drops around 0.3v below what I set in the BIOS. Temps are very good even when using 1.4v. Any help at all would be greatly appreciated.
Specs:
CPU:i7 8700k
Motherboard: ASRock Z370 Pro 4
GPU: Nvidia GTX 1080ti Founders Edition
RAM: 2 x 8GB Corsair Vengeance LPX 3000MHz
Cooler: Corsair H75 AIO
Storage: 2 x 1TB
Power Supply: EVGA 600w 80 Plus White
Specs:
CPU:i7 8700k
Storage: 2 x 1TB
