See if your motherboard can handle the baseclock first.
Disable HT
Disable all cores (apart from one of course)
Set your lowest multi
Lower your memory to its lowest multi.
Adjust QPI accordingly.
Raise baseclock/vcore until you hit a limit.
To get high baseclock you may need to also raise PCIe frequency 105-110 maybe higher. Just be careful as you may lose USB/network with such high PCIe. If thats the case raise IOH core to compensate to 1.2 (1.1v stock iirc).
Once you know your chip/mobo can reach that baseclock you can start enabling your cores etc.
Getting to 4.5+ is tricky, i have managed 4.55ghz for the custom pc benchmark thread. I did have to crossflash my p6td v2 though to stop the turbo throttling.
