I7 920 basic questions for o/c
12 Aug 2004
Telford, UK
Hi lads, i know many of you have been clocking this chip and i have looked on site but cant find what i am after.
Has anyone got a simple explaination to how the new teck works in the bios?
My problem is i popped into o/c yesterday and got:
I7 920 oem
Gigabyts GA-X58A-UD3R
6x2 ocZ 1600 Mhz mem (OCZB1600LV6GK)
and a water block for the cpu.
As the new CPU clocking is different from my old E6300 i dont know what to alter to make my ram run at the correct speed (i dont think it is). Currently i have everything on Auto or default in the bios but my ram speed is 1066 and i thought it was 1600?
CPUZ is showing:
Dram 539MHz
2:8
NB 2159MHz
7,7,7,19
cpu x20
Bus speed 134.9MHz
FDS 2428.9MHz
I really happy with the upgrade as my water cooling is keeping the I7 cooler than my E6300 ATM, but i do want to clock it up to 3Ghz min. Until i know and understand what all the bios bits do i wont touch a thing.
Any links and tips welcome.
Cheers
what ram do you have....an easy clock for the the i7 on that board is
voltage 1.14
20x18blck
dram voltage 1.64
ive timmings set 8,8,8,24x8ratio
qpi/voltage1.32
disable intel turbo
enable vdroop
I have exactly the same setup mate. If you need 1600mhz RAM, switch the memory multiplier from auto to 12.0 I believe. You will see what speed it hits before you reboot (Gigabyte show the before and after speeds just under the option on that board).
