i7 920 C0 stepping
9 Nov 2009
England
I've got a 360 rad, 3 sharkoon golf fans in the rad, and an EK-Supreme HF Nickel water block, and a XSPC RAD/PUMP combined.. using MX-3 my idle temps were 33 - 35 at the start, now they seem to be 40 or 44.. should I be worried about the rise in temps like this? all housed in the 800D case.
Also, I just had a 124 BSOD, with 1333 MHz of ram at 3.8 ghz, using 200 x 19, and 1.35, would getting better ram fix this? 1600, or 2000 mhz.. i want to push to 4.2
you will struggle to get a C0 to 4.2ghz.... mine is at 180 x 21 1.35v.....if i go any higher i need much more vcore and its not 100% stable.....my idle temps are 29c on no load using a 360 tfc plus 6 noctua fans in push pull config....if you can maybe look at changing your fans to something with good static pressure and get 6....my ram is corsair gt and its running at 1900mhz with that multiplier
