hi everyone
I got a i7 920 D0 chip from ocuk and in the bios it says its default voltage is 1.275 even after i load setup defaults. I thought that these chips ran on less voltage then this. is this right? also i can get to 4.2ghz stable but i need 1.375v and and that gives me around 83c of heat.
it seems like everyone is able to run this chip at a much lower voltage at 4.2 ghz is it just that i got a unlucky batch? it is 3908A429 i have to use 1.35v for qpi/vtt also is this normal for the D0?
also its pretty obvious that i am not running the stock cooler if i am at around 83c with 1.375v, and that is an ok temp for that voltage on air. also amout of ram in in my sig.
