Hi everyone,
im o/cing my i7920 on a gigabyte ud5.
Currently i have a bclk of 133 (totaling 3.08GHz). However, raising it anyfurther will cause it to crash (i.e. to 134). Temps are on average of 60 C at 22 C ambient but it is still blue screening on prime at any higher rate. i have increased the VCore which hasn't had an affect, reduced RAM speed to under manufacturer settings (samsung standard 1gb sticks @ 1333) I have also increased RAM voltage and the QPI voltage and speeds as i know these are automatically changed when the bclk is increased.
I am running on air but the comp pushes just under 600cfm and case temps are quite low. All temps indicate i should be able to get more out the CPU.
I suppose to get to the point, my question is what should i look at next to further increase the CPU speed?
