Hey, so I got some settings and, I know a little bit so started playing around.
My problem is that I'm not sure what is normal for voltages.
Anyway, here is a pick from CPU-Z of my current overclock ( 920 is stock 2.6Ghz ).
I want it to be as cool as possible, before I had it overclocked at 3.6, it ran ok but very hot.. so I eventually took it off. This is because of the voltages I believe, I also believe mine are too high.
I have a Corsair H-50 cooler ( details of rest of PC in my sig ).
Please can you help me make alterations to make this cooler?
Which voltages should I change? And, where would you start?
Thanks!
Thanks!
