- 22 Feb 2011
Hey guys i overclocked my i7 920 to 3.6ghz this is my first time doing this so bear with me.
I did a stress test for one hour using prime95 also had speedfan to check the temp my cpu is sitting at 66c full load (100%) and 41c normal load and each core is 51-52c. Is it safe to leave it at that and consider it a success?
Im using this as my cpu cooler http://www.pcper.com/article.php?aid=771&type=expert&pid=1
Do you think i could try and increase it more?
Settings are
CPU Ratio: 18
BLCK Freq: 200
PCIE Freq : 100
Dram : 1600
CPU Voltage : 1.35
CPU PPL Volt : 1.9
QPI/Dram : 1.35
IO Volt :1.14
DRAM bus voltage : 1.6
Settings are
CPU Ratio: 18
BLCK Freq: 200
PCIE Freq : 100
Dram : 1600
CPU Voltage : 1.35
CPU PPL Volt : 1.9
QPI/Dram : 1.35
IO Volt :1.14
