- 9 Oct 2009
- United Kingdom
Hi evening folks. I'm looking for a little bit of advice and guidance on overclocking my rig tonight. Spec below has been running at 3.6GHz on stock voltages for around 10months or so and I haven't had any trouble with it. I feel the time has now come for me to try to see how far my cpu can go.
Current spec;
i7 920 D0 Stepping
Titan Fennrir cpu cooler
Foxconn Bloodrage gti x58 motherboard
OCZ gold 6GB (3x2GB) DDR3 tripple channel RAM
Corsair HX750W PSU
Coolermaster CM690 Case with addition 120mm case fans
I've had a read through varies stickys and the official i7 overclocking thread and have tried various settings in the bios but nothing I do seems to be stable. I am a noob overclocking so apologies for any silly questions in advance.
Temperatures seemed a little on the high side even when running @3.6 see below:
OK so onto my settings;
CPU FEATURES;
PPM DISABLED
EXECUTE DISABLE BIT ENABLED
VIRTUALIZATION ENALBED
HYPERTHREADING ENALBED
ACTIVE PROCESSOR CORES ALL
CURRENT FEEDBACK OVERIDE ENABLED
MEMORY;
IMC CONFIGURATION ENABLED
CHANNEL CONFIG INDEPENDENT
CHANNEL INTERLEAVING 6 WAY
RANK INTERLEAVING 4 WAY
VIRTUAL XMP DISABLED
DRAM TIMING CONTROL BY SDP
CPU VOLTAGES;
CPU CORE VOLTAGE Default
CPU TARGET CORE VOLTAGE 1.22500
CPU Vdroop Compensation DISABLED
CPU VTT (UNCORE) VLTE Default
1.8V PLL VOLTAGE SETTING 1.800V
CPU CLOCK AMPLITUDE CTRL 0.800V
DRAM VOLTAGE 1.60V
X58 IOH CORE VOLTAGE 1.10v
X58 IOH VCCA 1.1v 1.108v
X58 IOH VCCA 1.5v 1.506v
ICH10 SB Voltage 1.506v
CPU TURBO DISABLED
SYSTEM TURBO ENABLED
CPU Bclock (FSB) 180MHz
QPI LINK FAST MODE ENABLED
QPI MULTIPLIER Auto
QPI TARGET SPEED 3245MHz
CPU CORE MULTIPLIER x20
CPU CORE TARGET SPEED 3606MHz
CPU UNCORE MULTIPLIER AUTO
CPU UNCORE TARGET SPEED 2887MHz
MEMORY BUS MULTIPLIER AUTO
MEMORY BUS TARGET SPEED 1444MHz (DDR3 1444)
CPU CLOCK SKEW 0ps
IOH CLOCK SKEW 0ps
Any help would be much appreciated!
Current spec;
i7 920 D0 Stepping
Corsair HX750W PSU
CPU FEATURES;
PPM DISABLED
MEMORY;
CPU VOLTAGES;
DRAM VOLTAGE 1.60V
CPU TURBO DISABLED
QPI MULTIPLIER Auto
CPU CLOCK SKEW 0ps
IOH CLOCK SKEW 0ps
