i7 920 overclocking vs. TURBO mode?
Turbo mode on the 920 only clocks to 2.93ghz if I recall, so the answer depends on how high you manually clock it!
Cheers reflux! Manual overclocking it is then :) I'll prob try to push it to 4Ghz.
What is the highest safe temp on the i7 920?
4ghz should be pretty easy. Max safe temp under stress testing load I would say is about 80 c measured with real temp or core temp.
Yep, manual overclocking all the way, with turbo enabled (21x multi) its easier to get a clock stable as opposed to 20x on x58 boards, currently running 21x193 here on an asus p6t deluxe v2.
