Hey, I'm currently running an i7 920 with a Noctua NH-U12P (Using provided compound). The instructions said to just apply a dot in the middle of the CPU and then attach the heatsink, however I was under the impression from a guide I read that it needed to be spreaded, so I did that.
My idle temps are around 35C and a stress test on prime95 gets it upto 55C+ (58-60C is the max).
I was wondering how good/bad that is? This being my first build, I may have done something wrong or whatever. I was planning to overclock, do I have enough headroom to do so?
My cable management is good, I'm using a Antec 902 and the are no wires between the top front fan and the heatsink intake fan.
If my temps are actually too hot, I was planning to use some AS5 and just apply a pea sized dot to the middle of my CPU then attach the heatseak, would this work?
Looking forward to the comments, and thanks
Kasc.
Kasc.
