i7 920 - what to upgrade to?
18 Oct 2005
So it's that time to upgrade (specs in sig) this processor has served me brilliantly over the years, but it's beginning to show it's age a little and its time to upgrade (since I also want a new case etc).
What sort of improvement am I going to see going to the 4790k or one of the new 6 cores? I'm still torn between both of them. I mostly game but also do some encoding and would like to twitch stream at times as well, so I'm thinking 6 cores would make that a better experience?
thoughts appreciated.
So far as good as or better than my previously held 4670K, both @ 4GHz. That's just opinion, I have no benchmarks to back that up. :)
Wow this is amazing. Thanks! Just ordered one for £65 shipped! I may still get a new case and cooler though, but considering i was ready to spend £1k, spending a couple of hundred is much better :)
Cinebench and threaded apps the 5650 is around the same as the 4790k, not the 4670.
I've seen a 5670 or whatever they're called (the next one up from the 5650) bench at 4.6ghz and was 100 points behind my 3970x @ 4.6ghz.
They're awesome chips. In fact, they'd be every bit as good as any other Intel hex core apart from the clock defacit they have. 4.2 is a good clock to get :)
Going to aim for 4.2 minimum. The higher multi on the 5675 should help with that. Just hope my motherboard is compatible
I went from i7 920 to 4790k, very happy with it. This was before Haswell E was released.
The 5650 is a very good chip, but I didn't know if I'd use 6 cores, and it seemed to me that IPC would be lower with the older chip, and given that I'd hit higher clocks with the 4790k, I'd get better performance.
I also wanted native SATA3, which on my board I didn't have, I had to use a PCIe x1 card for my SSDs to get a bit more speed over SATA2.
That said, it turned a £65 upgrade into a £500 odd upgrade by the time I'd replaced RAM as well (didn't want to downgrade from 12gb, and only had 4 dimm slots on z97.) I'm not sure if it was that much better that it was worth it.
If I had my time again, I'd probably have held out for Haswell-E and x99. Not for more cores, but for more PCIe lanes. I kind of want to go to 3 way SLi but can't without some stupidly expensive z97 board with a PCIe bridge chip. Also, my £240 of DDR3 won't last me through my next couple of upgrades as we'll probably see DDR4 with Skylake.
5650 is a very good choice I think.
I'm hoping that with the 5675's higher multiplier I'll be able to get 4.2-4.4 ghz, this should give me a nice boost obver me 3.8ghz 920. This boost may be enough to keep me going for another year and for a lot less money, then I can save up for a porper upgrade in a year's time.
And it's only a 95W TDP rather than the 130W of your 920 @ 2.66ghz.
That's quite impressive, and should make cooling it easier.
At 32nm, I think I remember there being some extra instructions over the original 45nm core of the 920, so you might see some slight IPC boost too, seems like a good buy.
I have done that with my i7 920 and my new x5650, to be honest I was expecting to see at least 2% higher IPC, but sadly it was exactly the same.
btw I only tested Cinebench R15 and wPrime.
