Hi. I just set up my new rig.
i7920 + P6T Deluxe V2.
I wanted to overclock my 920 to about 3.7-3.8ghz i don't really need it much higher at the moment. My friend gave me his OC settings since he has the same setup really. (Never OC'd anything in my life, see?
Though when i run Prime95 with small FFT it runs my temps up to 80c and that's only 3.7 that doesn't seem right to me. Right?
It is as follows:
AI Tweaker Menu
Ai Overclock Tuner => Manual
Intel Speed Step Tech => Disabled
Intel Turbo Tech => Disabled
CPU Ratio => Auto
BCLK Freq => 186
PCIE Freq => 100
DRAM Freq => DDR3-1491MHz
UCLK Freq => Auto
QPI Link Data Rate => Auto
Voltages
CPU Voltage => 1.35
CPU PLL Voltage => 1.96
QPI/DRAM Core Voltage => 1.35
DRAM Bus Voltage => 1.64
CPU Differential Amplitude => 800mV
... all other voltages to Auto
[Screenshot]
Any help as to what i can do to bring the temps down a little would be great. I don't want to be blowing things up now would i? xD
)Though when i run Prime95 with small FFT it runs my temps up to 80c and that's only 3.7 that doesn't seem right to me. Right?
It is as follows:
AI Tweaker Menu
CPU Ratio => Auto
BCLK Freq => 186
PCIE Freq => 100
UCLK Freq => Auto
Voltages
CPU Voltage => 1.35
[Screenshot]
