i7 930 oc temperature
3 Aug 2011
Lancashire
Using a H80
I would be very grateful if you could comment on the overclock tell me what you think.
Thanks Tom
Voltage is quite high for 3.57. If you want to keep it at 3.57 you might be able to drop that vore a bit. Mines at 1.1v.
higher higher,i hit 4.2ghz with 1.23v under load,but i have another chip that needs 1.36v for 4.2ghz so its down to each chip
1.31 for 4.2ghz on my 920, though ive backed it down to 4ghz at 20x200 to have the ram at 1600mhz. My 930 is currently at 3.6ghz on 1.18vcore, still got to do a bit of tweaking on it, and get some better fans for the cooler before i push it higher.
I would love to hit the 4ghz mark but my ram is holding me back :/
Running 3x2GB Corsair 1333mhz in triple channel, I'm not really sure how to overclock ram and really don't want to mess it up.
